Alignment help
Old Feb 25, 2016 | 03:53 AM
Prismatic's Avatar
Prismatic
Default Alignment help
New truck (will make a thread on that soon)
2004 Ram 1500 SLT Sport Quad Cab HEMI rwd
Put my lift on. 3 inch spindle, 2 inch spacer in the front, 3 inch blocks in the rear.
Took it in for an alignment today. Shop got the toe and camber dialed in but said the caster was maxed out and unable to be adjusted. Is there anything I can do to get the caster back into spec?
results from Evans Tire
Thanks guys
Old Feb 25, 2016 | 11:32 AM
p38251's Avatar
p38251
Caster is not a tire wearing angle. However I do believe they make kits to correct it. If the truck drives right, IMO leave it.
Old Feb 26, 2016 | 10:25 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Maybe try a different shop? I've had mine aligned without issues and I have more lift than you.
