02 dodge 3.7l to 5.7l hemi swap cruise control not working
Old Mar 10, 2016 | 03:43 PM
justin0943's Avatar
justin0943
Default 02 dodge 3.7l to 5.7l hemi swap cruise control not working
I did a hemi swap the abs light flash thats was only because I didn't have the front hub with the speed senor I did put the new hub with the speed sensor the abs is still flashing and the cruise control still don't work I need the cruise control
Old Mar 11, 2016 | 10:53 AM
HemiLonestar's Avatar
HemiLonestar
Cruise is controlled electronically, did you keep the electronic TB or use a cable one? Did you swap the 5.7 PCM?
Old Mar 12, 2016 | 10:19 AM
justin0943's Avatar
justin0943
yes I change everything out it all came from same 04 truck even the dash harness and the only codes that come up is for my o2 sensor which I'm not using.
Old Mar 12, 2016 | 09:09 PM
p38251's Avatar
p38251
The truck came with cruise? Could be a fuse. Did you reset the pcm after the new bearing?
Old Mar 12, 2016 | 09:58 PM
justin0943's Avatar
justin0943
no I haven't reset the pcm yet but it did have cruise I got the steering colume it just like my 02 but design different and where is the fuse for it.
Old Mar 14, 2016 | 10:22 PM
justin0943's Avatar
justin0943
okay guys I think I know whats wrong with it i went to my buddy shop he has a newer scanner with more funtion to it so now I get more codes
code 83 Tire revolution per minute out of range
82 tone ring teeth fatory out of range
81 brake switch stuck
65 power relay open
p0593 cruise control muli-function input b high
p0585 cruise control multi-function input a/b correlation
Old Mar 15, 2016 | 11:13 AM
HemiLonestar
Ok, sounds like the computer is getting conflicting speed signals. Do you have the ability to change the tire size? Sounds like it isn't liking your brake switch either. If you were closer I could probably fix these with the DRBIII, does your buddy have this?
Old Mar 15, 2016 | 03:07 PM
justin0943's Avatar
justin0943
I live in GA I just replace the brake switch now that code gone an also the horn doesn't work unless i set the alarm off but my buddy doesn't have a program tool to set tires size and all, a shop in town should so thats my next thing I'm going to do an also change out the air Bag Clock Spring with the horn not working I'm thing it went bad also
Old Mar 15, 2016 | 06:56 PM
Prismatic's Avatar
Prismatic
They're very easy to snap if you have the column out and unlocked. Always take care with a removed column to not rotate it.
Old Mar 17, 2016 | 11:03 AM
HemiLonestar
This^^, also helps to ensure you have the wheel (and wheels) straight ahead when you do it, there is a procedure in the service manual (you can download it from this site)
