Radio Problems
Old Mar 20, 2016 | 08:59 PM
Ezell09's Avatar
Ezell09
Default Radio Problems
I own an 03 dodge 1500 Reg. Cab. I went to Install my aftermarket radio and it appears that the previous owner cut the reverse wire harness off and all that I'm left with is wires. I hate riding withOut music. I would like to straight wire the radio but I have never done it before I'm sure it can't be to hard. Can anybody help and explain what I should do because I have no idea?????
Thanks
Old Mar 21, 2016 | 09:28 AM
You need a constant 12 volt source for the radio presets, a switched 12 volt source for the radio itself and a ground. A multimeter will help you identify which wires are ground and which are the switched and constant power sources. Got this off the web. Not sure if it applies to all sound systems or not.
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located Behind The Glove Box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Light Green/Red
Left Front Speaker Negative Wire (-): Light Green/Dark Green
Right Front Speaker Positive Wire (+): Light Blue/Violet
Right Front Speaker Negative Wire (-): Light Blue/Black
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Red
Left Rear Speaker Negative Wire (-): White/Black
Right Rear Speaker Positive Wire (+): Tan/Violet
Right Rear Speaker Negative Wire (-): Tan/Black
Old Mar 22, 2016 | 04:54 AM
a303101's Avatar
a303101
just buy the adapter plug u need for new stereo and wire it in using the wire color match ups.. reverse wire harness??? u mean the wire harness..
