LSD Retaining Clip?
Old Mar 21, 2016 | 09:11 PM
Zazoos's Avatar
Zazoos
Default LSD Retaining Clip?
Found one of the retaining clips in the bottom of the pumpkin today. The rear end was not showing any signs of problems. Rather tha buying a new carrier, can I just buy a new retaining clip, or should can I remove both clips and just run without them?
Thanks
Old Mar 23, 2016 | 06:20 PM
cruzer55's Avatar
cruzer55
NO !!They are a major item.Just replace with the press in Green bearing.Shop can have you in& out in 2 hrs.Just a Thought............
Old Mar 23, 2016 | 11:28 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
They are only used to hold the clutch pack together during assembly. Once assembled they are useless. If yours came out, don't worry about it. Change the oil and keep driving it.
