05 hemi wont start..
Old Apr 13, 2016 | 08:08 PM
Omgitshugo's Avatar
Omgitshugo
Default 05 hemi wont start..
hello everyone I have a 2005 single cab ram hemi 4x4 that doesn't want to start. it cranks and cranks but doesn't start. check engine light code was PO113 which is for the IAT and I have checked all the fuses and they are all in working order, cleaned out the throttle body / stock intake and nothing. I cannot hear the fuel pump buzz or whine or any sign of it which leads me think it is bad, my question is, can a fuel pump go bad overnight? in a matter of 12 hours or so? turned it on at 10:30pm got home at 11, woke up next morning and around 9am is when it no longer started. thanks for your time, any help is greatly appreciated. I have tried searching for the problem but have not found a case similar enough having to do with the fuel pump going bad overnight when the truck ran perfect before.
Old Apr 13, 2016 | 08:15 PM
MikeHTally's Avatar
MikeHTally
The pump in my Dodge Wagon went bad driving down the street. Do you "run it down to fumes" much?
Old Apr 13, 2016 | 08:21 PM
Omgitshugo's Avatar
Omgitshugo
It never has less then half a tank in it, that's why I am curious if it really could go bad that quick, before it would start first try with just a tap on the key literally. it turned on perfect every other time in the 3 months i've had it.
Old Apr 23, 2016 | 01:13 PM
superdak05's Avatar
superdak05
rent a pressure gauge and hook it up to your Schrader valve and see what you get for a reading if any.
Old Apr 25, 2016 | 12:50 PM
BigHorn70's Avatar
BigHorn70
Check your ground/motor and ground/chassis. It can be corroded
