Wiring problems on door window, door lock, speaker or door light ???
This is what happens you have to remove wiring plugs from door jam remove door panel and speaker and Pull wiring harness from the spot where the speaker was and pullback Rubber cover this is what you will find ...almost all wires were cut from door opening and closing
The following users liked this post:
Mopartech64 (04-13-2023)
fixed a billion of these, but they're not too tough with a good pick set and wire, soldier,shrink-wrap, and a quality pinpoint iron. The biggest struggle is pulling the harness into the door and snaking it out below the regulator, you must unplug your power window motor to get enough slack to have plenty of space to properly repair the wires with jumpers of the same size. The best method is to de-pin the wires one at a time from the weather plug and install a full length jumper with new pin back into the plug. Your soldier point should be well inside the door to avoid flexing your repair joints for a long lasting ( if not permanent ) repair
Ram man2003 (04-24-2023)
Trending Topics
