Where to find drive shaft spacer
I lifted up my 03 Dodge Ram 1500. I can't find a driveshaft spacer for my truck anywhere. Does anybody know where to find one?
Not sure what you are asking? You had one and lost it. It helps us to help you if you can be as detailed as possible when asking questions and provide detailed vehicle information such as 2 or 4 wheel drive, etc.
It is a 2003 Dodge Ram 1500 4wd. I have a 8 inch lift on the front and 7 on the back. I am having problems with the angles and driveshaft noise. I thought it would be cheaper to find a driveshaft spacer than to go and have a longer driveshaft made. I have searched everywhere and can't find a spacer for my truck. I need help finding one.
The lift came with one so I know there has to be one I can buy. But I added another inch of add-a-leafs in the back and a 2 inch leveling kit in the front. And now the shafts are too short. I was looking for a bigger one.
WaylonCoggins, Were you ever able to find a drive shaft spacer? I'm also looking for one for my 04 Dodge Ram 1500 2WD. Was also wondering which company you got the lift from.
Trending Topics
1 inch spacers are available at
https://www.4crawler.com/4x4/ForSale...html#Dodge9.25
Just make sure to measure your pinion flange, due to there being 2 similar but different flanges.
