Cab light replacement
Old Jul 16, 2016 | 11:49 AM
jamez's Avatar
jamez
Question Cab light replacement HELP!
So I ordered some white LED lights to replace the amber cab lights on my 2500.
The lights I ordered are "plug-n-play", however, when I took the first cab light off I could see they are hard-wired and there aren't any existing light sockets.
I disconnected the positive battery terminal, and decided to splice in the new LED light.
AND HERE IS WHERE I EFFED UP...I left the LED light with bare, but connected, wires on the roof and reconnected the positive battery terminal, and saw the remaining amber lights light up, but not the LED. Then I adjusted the LED light (I think touching the bare wires to the roof) and all the amber lights went out. I spliced the first amber light back in, and now I have ZERO cab lights.
Is there a specific fuse that I may have blown?
Or did all the amber lights blow?
Or is there another reason the lights aren't working?
Any help is appreciated!
Old Jul 16, 2016 | 05:54 PM
p38251's Avatar
p38251
I thought there was a plug under the headliner for those. Sounds like you may have blown a fuse. You can use a power probe, test light, or multi meter to check fuses.
Old Jul 16, 2016 | 06:03 PM
jamez's Avatar
jamez
I didn't remove the headliner, I just unscrewed the light housings on top of the cab. The holes under the light housing are a little bigger than 2 fingers wide, so I'm not sure if this is OEM or aftermarket.
My new lights have a red (power) and black (ground) wires, and the existing wires in my truck are white w/grey stripe (power?) and black (ground?).
Old Jul 16, 2016 | 06:53 PM
p38251's Avatar
p38251
Some do have the cab lights from the factory. Check Weeds page he has service manuals, that may have electrical diagrams to make it easier. Mine doesn't have cab lights.
Old Jul 17, 2016 | 05:23 AM
Friar Tuck's Avatar
Friar Tuck
Lightbulb Fuse for Clearance Lights
Fuse 16 (15 amp) in TIPM.
No individual connectors. They're all spliced together just above the rear view mirror behind the headliner.
WHITE/GRAY IS 12 VOLTS.
BLACK IS GROUND.
Old Jul 17, 2016 | 09:18 AM
jamez's Avatar
jamez
BLACK IS GROUND.
Thanks for this info!
