4.7 stalls, map sensor?
Old Aug 6, 2016 | 11:03 AM
a_r_fowler's Avatar
a_r_fowler
Default 4.7 stalls, map sensor?
03 1500 with 4.7. Engine runs fine with no codes except within a minute of startup after going about 500 feet it begins to bog down as if starving for fuel. If accelerator is pushed to wide open it will recover and drive fine until turned off. Have cleaned throttle body but could this be a sensor issue? Thanks for any help.
Old Aug 8, 2016 | 03:40 AM
Friar Tuck's Avatar
Friar Tuck
Talking
No codes at all? Sensors create codes, so probably not a bad sensor.
After all, they're there to detect problems. They're your friend!
Old Aug 8, 2016 | 06:39 AM
a_r_fowler's Avatar
a_r_fowler
No codes but something is going on. I have a recall on the airbag maybe i can check on a update while at the dealer.
Old Aug 8, 2016 | 09:58 AM
DodgeCares's Avatar
DodgeCares
I'd recommend having this addressed during your recall appointment. Feel free to DM if you're in need of further assistance. - Kevin T, Social Connect Team
Old Aug 8, 2016 | 09:40 PM
Friar Tuck's Avatar
Friar Tuck
Check the fuel pressure. Could be a fuel pump going bad or a bad check valve if there is one. A fuel pressure gauge will answer both questions. Might be able to borrow one from your auto parts store.
Old Aug 8, 2016 | 10:37 PM
a_r_fowler's Avatar
a_r_fowler
Thanks friar, i had just read a post about stalls after startup indicating a possible pump issue. Going to check service manual look into checking the pressure.
Old Aug 9, 2016 | 06:32 PM
a_r_fowler's Avatar
a_r_fowler
Checked the pressure at the fuel rail. 47 psi which seems to be in spec. Anything i might be missing?
Old Aug 9, 2016 | 10:36 PM
Friar Tuck's Avatar
Friar Tuck
Question
Does the pressure hold steady after you shut it off?
Old Aug 10, 2016 | 08:10 AM
a_r_fowler's Avatar
a_r_fowler
When key is turned to on position pressure goes to about 10, when engine is started it goes to 46 pretty quickly. While the engine was still cold if it is switched off the pressure would drop to 25 in 30 seconds and down to about 15 in a minute and gradually dropping. When the engine is warmed up then switched off it seems the pressure would hold steady around 46. Could I be getting air into the fuel line and the hesitation after startup is the air purging out? Thanks for any help!
Old Aug 10, 2016 | 03:27 PM
p38251's Avatar
p38251
Almost sounds like the pump is dying. Or pressure regulator issue.
