Projector Headlights
Old Nov 11, 2005 | 07:15 PM
dc7derek's Avatar
dc7derek
Default Projector Headlights
Hey, i wanted to know if anyone knows how to increase the light level thats seen when driving on the new projector headlights. The level that its at only goes out about 10 feet in front of my truck so I need to increase that so does anybody know how to adjust the level? If you do know can you list the steps so that i can follow it. thanks
Old Nov 11, 2005 | 08:46 PM
kenihemi's Avatar
kenihemi
Default RE: Projector Headlights
You have to remove the whole assembly.
There are 2 screws on the bottom of the low beams.
They are the adjustment screws. Screw them both in around 4 turns and see what happens. Then take it from there. One is on the lower left, the other is on the lower right, so by turning only one of them, you can move the light left or right.
Best to do it with 2 guys/gals so 1 can hold it in place to test it against a wall.
Take a similar truck that has stock lights and mark a wall where the stock lights hit, then put your truck in the same place and adjust yours so they hit in the same place.
Took me around 4 hours.
The high beams didn't need adjusting.
