Front upper ball joint
Old Aug 17, 2016 | 07:55 PM
RamRvca's Avatar
RamRvca
Default Front upper ball joint
08 dodge ram 1500 2wd 5 lug
i ran into this K7460 ball joint fitment chart just wanted to ask everyone if this sounds correct as far as they are different suspensions i assume??
from vendors online they show that k7460
will they'll fit ........??
Dodge Ram 1500 06-08
Dodge Ram 2500 03-10
Dodge Ram 3500 03-10
Ram 2500 2011-2015
Ram 3500 2011-15
let me know i have parts guys arguing with me but seems alot of vendors show this so some clarify thank you
Old Aug 17, 2016 | 11:27 PM
KasperR34's Avatar
KasperR34
So since you have a 1500, it narrows it down.
I'm not 100% on the 2wd 06+, I don't think they changed the suspension setup at all for the 4x2. To my knowledge, your upper should be like mine, where you buy the whole UCA and just switch it out.
Hopefully someone with your year can chime in and correct or back me up. I know the 06+ 4x4 has different front suspension than my 05.
Old Aug 18, 2016 | 12:02 AM
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
I know the suspension on the 3.5+ ('06 on) is different on the 4WD. The 2WD is a different animal, entirely, for any year. However, the UBJ should be part of the UCA, which is one piece.
Found this online:
http://www.********.com/f76/diy_ball...%5B2wd%5D-200/
It's for a 2004 RWD, but the process looks the same as a 4WD. Looking up parts for it by "2008 Ram 1500 Upper Ball Joint" shows the whole UCA. Looks like that's what you are going to have to do. It's not hard -- probably easier than popping out a ball joint.
Old Aug 18, 2016 | 12:28 AM
RamRvca's Avatar
RamRvca
I ended up finding this K80628 bud from XRF Chassis dot com Eliminates having to replace the entire arm.
Old Aug 18, 2016 | 12:55 AM
KasperR34's Avatar
KasperR34
If you have a Control Arm that's meant to be fully replaced, trying to undue that is a bad Idea. The UCA is a very cheap part anyways. I modded mine to just me greasable for longevity. But i'd never try to separate the BJ and the Arm.
Old Aug 22, 2016 | 09:25 AM
TejasMtnBiker's Avatar
TejasMtnBiker
I wouldn't buy ebay ball joints or uca's just because of failure warranty hassle to ship back, but when ball joints are toast on a ram 2wd usually bushings in the uca are worn as well in my 12 years of owning rams
Old Nov 2, 2016 | 10:21 PM
RamRvca's Avatar
RamRvca
basic question will front upper control arms from a 2005 dodge ram 1500 2wd fit a 2008 dodge ram 1500 2wd truck? are there any differences?
