2005 dodge raM 1500 4.7 OIL PRESSURE ISSUES
Old Sep 4, 2016 | 09:45 PM
jws123's Avatar
jws123
Default 2005 dodge raM 1500 4.7 OIL PRESSURE ISSUES
I have a 2005 dodge raM 1500 4.7 207k with oil pressure issues when its hot and i come to a light the pressure drops and check gauges goes on i changed the oil pump timing chain tensioners and the sensor i just ordered another sensor to make sure what else could be doing this.... i am going to get mechanical gauge next but do the dash board displays go bad often?
Old Sep 4, 2016 | 09:46 PM
djibara's Avatar
djibara
Did you try replacing the sending unit?
Old Sep 4, 2016 | 09:54 PM
jws123's Avatar
jws123
yes i just did i am getting another one different brand to make sure.
Old Sep 5, 2016 | 06:07 AM
Prismatic's Avatar
Prismatic
It's really just a switch. It either shows pressure or no pressure. The gauge in the dash is no different than a dummy light in any other vehicle.
Have you checked the actual pressure with another gauge?
Old Sep 5, 2016 | 05:38 PM
jws123's Avatar
jws123
is there a way to jump out the pressure switch so when i put a mechanical one on permanently i dont have to listen to DING DING DING every time i come to the light i know there is pressure i just replaced the pump engine sounds fine i tried 2 new sensors still does it.
Old Sep 5, 2016 | 05:51 PM
jws123's Avatar
jws123
also what is normal oil pressure for this engine? when hot
Old Sep 6, 2016 | 07:33 PM
Prismatic's Avatar
Prismatic
Just piece together a brass T fitting and keep the original on there. I think the size is 1/4 or 1/2 npt
Edit - and while the pump moves fluid, pressure is generated by the tolerances between the internal components of the engine. 50 new oil pumps wont fix a worn out bearing.
Old Sep 10, 2016 | 10:47 AM
superdak05's Avatar
superdak05
depending on the current temps in your area, You may wanna switch to a different weight to see if the issues remains
