2008 Ram 3500 C&C no steering, no brakes quite suddenly
Old Sep 12, 2016 | 06:51 PM
Jinx the Cat's Avatar
Jinx the Cat
Default 2008 Ram 3500 C&C no steering, no brakes quite suddenly
Hello all:
I have a 3500 single axle dump body with a 5.7 hemi. The truck currently has 12,000 miles on it and I've been the only owner.
Last night I notice a bit of a hitch in the steering, like you might get with a low fluid situation.
Today I can't move the wheel at all, and don't have any brakes either. Fluids in both systems are fine. I hope this isn't some TIPM unit problem again.
Any ideas?
Thanks
Old Sep 12, 2016 | 09:56 PM
Jinx the Cat
https://dodgeforum.com/forum/dodge-r...no-brakes.html
I did find this, but still don't understand how this all works. I can't find any fluid leaks and reservoirs are full.
Old Sep 12, 2016 | 10:31 PM
p38251's Avatar
p38251
Does it have hydro boost like the diesels?
Old Sep 12, 2016 | 10:43 PM
Jinx the Cat
I believe it does. It does not have a rack and pinion steering system, but rather the old gear steering box and I don't see a vacuum power brake unit.
It is a 3500 base model, but quite heavy duty.
Old Sep 12, 2016 | 10:51 PM
Jinx the Cat
yes, it is a hydro boost system. I guess this truck wanted to be a diesel.
Old Sep 13, 2016 | 03:47 PM
p38251's Avatar
p38251
Hydro boost unit needs replacing.
