trans fluid change.
Old Sep 29, 2016 | 08:00 AM
Buckrabbit's Avatar
Buckrabbit
Default trans fluid change.
Hey guys, could someone please tell me the quantity of transmission fluid I need for a 1500 Ram transmission, I hope to do a service this weekend, will include filter change too, thanks.
Old Sep 29, 2016 | 11:43 AM
Not sure of the exact amount, but what I do is catch all that comes out, measure that using an old 5 qt oil jug, and then put the same amount back in. Then making sure it is at the proper level the normal way. Just dropping the pan will not completely drain the transmission.
Old Sep 29, 2016 | 04:51 PM
Buckrabbit's Avatar
Buckrabbit
What do I do to completely drain the trans, I thought dropping the pan would let out all of the fluid, is there something else to drain?
Old Sep 29, 2016 | 05:03 PM
Torque converter. Only way to completely change all the fluid is with a flush. But that is not recommended.
Old Oct 1, 2016 | 03:16 PM
MikeHTally's Avatar
MikeHTally
When I did my drop 'n' drain, it took seven quarts. Just a pan drop will not remove all the fluid. There'll be ~ nine quarts left.
