08 dodge ram ELECTRICAL
When fog lights are running(on) & switch high beams on, noticed the fog lights will turn off. Would love to keep fog lights operating when using high beam at all times and need some techs to chime in on how to work this here on the forum with out any trouble. have a 2008 dodge ram 1500 anyone out there has done this or simply knows, please explain how it was done thank you.I have found forums discussing the way it functions but, yet have seen a forum as to keep fogs on while high beams need to be used with out turning fog lights off
It's normal for the fogs to shut off when high beams are on. Probably a gubmint thing. Don't know why you'd want to do this but all that's needed is to tie the fog lights + lead to the high-beam lead. A better way is to put the fogs on a separate relay and fuse set up. Better control and less chance of fire.
Again some specifically explain how this can be done in steps since i am not sure where to begin or as other forums with light mods doing a simple wire jump but, place me into the right direction
you mentioned the fog lights + lead to the high-beam lead since i have an 08 ram and i am running all led lights would thid hold up against the tipm and not damage it whats your advice
