the deaded ABS and brake light again
Old Nov 2, 2016 | 02:39 PM
imnuts's Avatar
imnuts
Default the deaded ABS and brake light again
Hi All!
Now before you tell me to do a search.. I have ...... I have also replaced the hub/sensors in the front as well as the rearend. My speedo works fine but also my cruise only seems to work around 60 to 75 MPH to fast or slower and it won't even come on. I checked the resistance on all 3 new sensors and all seem to be within tolerences. Anyone have anything else i should check? this is very very frustrating
thanks
Rob
Old Nov 3, 2016 | 09:24 PM
big_horn1970's Avatar
big_horn1970
I have the same lights on, I had a local tire shop check it out and the code that they got said it was in the ABS pump electronic board, Sorry cant remember the exact code. Not going to worry about it to much as I don't drive the truck that often. I do pull a 20ft trailer and haven't had any problems with the braking system.
Old Nov 3, 2016 | 10:44 PM
imnuts's Avatar
imnuts
yeh i'm thinking i'm going to have to bite the bullet and take it to the dealer to get them to do scan. i could end up spending more then it worth if i don't.
