2004 RAM 1500 4x4 Linkage broken
Old Nov 3, 2016 | 04:25 PM
Lagspikes's Avatar
Lagspikes
Default 2004 RAM 1500 4x4 Linkage broken
Hello all,
first time posting but have lurked over some issues that I have had in the past.
I have a 2004 RAM 1500 Quad Cab. My linkage from my Transfer Case to shifter is broken and I can't seem to find the where the rod would go on the transfer case. I will provide pictures, I haven't bought the part yet but wanted to verify I bought the right part.
Thank you to all that help in my issue, sorry I am kind of new at working on my vehicles!
Part
Shifter missing linkage rod, unsure where the other side of it goes.
Old Nov 3, 2016 | 08:32 PM
jfotsch's Avatar
jfotsch
Climbed under to get you a shot of my linkage that is still in tact from factory!
OEM off-road 17's, BFG LT's, Airraid CAI, Cortex 3950 w/trans tune, Magnafolow y-pipe, Detroit TT, Mag Hytec trans and rear diff, Drilled/slotted pwr stop all 4, 190 t-stat, power wire, SRT A-pillar w/ trans temp gauge, Amsoil in the diffs, RP helped my tick.
Attached Thumbnails 2004 RAM 1500 4x4 Linkage broken-img_1054-1-.jpg   2004 RAM 1500 4x4 Linkage broken-img_1052-1-.jpg   2004 RAM 1500 4x4 Linkage broken-img_1053.jpg
Old Nov 3, 2016 | 08:36 PM
Lagspikes's Avatar
Lagspikes
Thank you so much for replying and the pictures.. I think that piece might've gotten ripped off on my truck. Here is a picture of that bolt I believe. Does anyone know my options with that control arm ripped off on the transfer case?
Old Nov 3, 2016 | 08:46 PM
jfotsch's Avatar
jfotsch
Hey Lagspikes, after posting the pictures I noticed they just did a post on this same thing. KasperR34 on 2-26-16.
Looks like they are making it work with parts from a turnbuckle, but they probably mention the real part you need too!!
Good luck!!!
Old Nov 3, 2016 | 08:57 PM
Lagspikes's Avatar
Lagspikes
Good luck!!!
Thank you! Only issue is they are using the control arm from the transfer case, which seems to be broken off on my truck. I guess I will need to either go to a dealer and see if they can find a piece for the transfer case so I can do the turnbuckle rod.
For anyone else, here is the link to the thread in question
