2002 ram rear end locked up
Old Nov 24, 2016 | 04:31 PM
jman985's Avatar
jman985
Default 2002 ram rear end locked up
I have a 2002 ram and i had the rear end lock up while driving the other day. Driveshaft feel onto the ground and everything. I know its a common issue but has anyone else gone through this recently? I'm looking for options on how to fix this without breaking the bank. I popped open the cover and a few gears have pieces broken off. Can i just buy all the gears and replace them or am i better off getting a new rear end?Any info will be greatly appreciated!!
Old Nov 25, 2016 | 11:44 AM
superdak05's Avatar
superdak05
look at the tsb for your years truck, they may have a recall for the c-clips. if not you will need a new ring and pinion, go to a reputable shop for the work
Old Nov 28, 2016 | 10:23 AM
HemiLonestar's Avatar
HemiLonestar
New R&P or find an 02-08 axle with the same gear ratio in good shape and swap it in.
