Hissing sound drivers side when in drive + other issue
Old 11-28-2016, 01:45 PM
Gorhad's Avatar
Gorhad
Gorhad is offline
Default Hissing sound drivers side when in drive + other issue
Hi all.
Could this be a vacuum leak
Hissing sound when in drive sounds like coming from drivers side, brakes are spongy too unless you compress a few times then they are OK. Then today started miss firing, stuck the torque app on it and came up with P0308 cylinder 8 misfire could they be all related?
Thanks in advance
Old 11-28-2016, 02:50 PM
p38251's Avatar
p38251
p38251 is offline
Yes vacuum leak. Sounds like brake booster. With the miss fire on only one cylinder I would think maybe time for plugs or a bad coil pack. IMO fix the vacuum leak first, clear the code see if it comes back.
Old 11-28-2016, 05:01 PM
Gorhad's Avatar
Gorhad
Gorhad is offline
Thanks so much p38251 really appreciate your input ill get onto it tomorrow
Old 11-28-2016, 05:09 PM
Gorhad's Avatar
Gorhad
Gorhad is offline
Can i ask how i would go about checking the vacuum leak on the brake booster please
Old 12-05-2016, 09:44 AM
ocdropzone's Avatar
ocdropzone
ocdropzone is offline
This might help
http://www.agcoauto.com/content/news/p2_articleid/129
Old 12-07-2016, 06:06 PM
AIR_RAM's Avatar
AIR_RAM
AIR_RAM is offline
Check the vacuum lines that pass under the drivers side closest to the exhaust. They tend to dry up and crack over the years. I had a few go bad on mine...
I would hear the leak every time I turned the engine off... I would hear a slight leaking sound underneath the truck...
Good Luck and please keep everyone posted.
SPEED SAFE, NICK
