multiple cyclinder misfire
2006 DODGE RAM 1500 SLT 4.7L
After swapping my 545RFE transmission, and reconnecting my battery, my engine has multiple cylinders misfiring.
ENGINE CODES
P0300
P0344
U0155
U0156
U0184
U0019
B212D
B210D
B162E
Some have told me that i just need to drive it to have PCM relearn itself. And some have told me to replace PCM.
I have replaced the camshaft sesnsor and the P0344 has disappeared. But all other codes remain as well as the multiple cylinder misfires.
Any help is greatly appreciated.
ENGINE CODES
P0300
P0344
U0155
U0156
U0184
U0019
B212D
B210D
B162E
i have the same trouble with mine, same truck , ive replaced ALL the sensors on the engine,coils, injectors, alt, bat, ive checked for vaccum leaks, none found, cleaned TB, new egr, pcv,iac, tps...nothing works....starts fine, but the longer it runs, the worse the idle gets, hesistates on take off, but seems to run fine on the hwy...i took it to a shop, i get multiple misfires code....let me know if you figure it out...cuz i havent
