Tires to lift
Old Feb 15, 2017 | 06:55 PM
Deadlymopar408's Avatar
Deadlymopar408
Default Tires to lift
So I have a 03 ram 1500 with 2" keys in already would like to put on a 3" body lift how big of a tire can I fit i already have on the truck 285/75/17 coopers on thoughts
Old Feb 15, 2017 | 09:55 PM
p38251's Avatar
p38251
If it's 4wd the fit with just leveling.
Old Feb 16, 2017 | 11:13 PM
Bigdtaylor88's Avatar
Bigdtaylor88
Default I need help please!
Ok, I have a 2006 Dodge Ram 1500 mega cab 2wd and I am wanting to put cst suspension 6.5" lift. At the moment, I want to leave my stock wheels, to save money and buy 35x12.5r17 for it. I was told in the description of the cst lift, that you would need to get at least 1.25" wheel spacers if you are staying with stock rims. I want to know what y'all think about that if there would be rubbing issues...? Also, would you space all 4 tires? And I guess that 37x12.5r17 would be too much? Pics or info would be great! I do plan on replacing the front bumper for added clearance... later on
Old Feb 16, 2017 | 11:17 PM
p38251's Avatar
p38251
IMO wheel spacers are trouble. Buy the correct rims. 37 are alot of tire. I hope you plane on re gearing.
Old Feb 16, 2017 | 11:22 PM
Bigdtaylor88
So what after market rims would you prefer? I'm new to this, and I know there's a lot to the offsets, back spacing, etc... I know they said for a max of 5" backspacing... I guess a certain amount of backspacing would take care of the spacing issue for rubbing?
Old Feb 17, 2017 | 07:30 PM
p38251's Avatar
p38251
Yes on the back spacing I believe it's 4-4.5. Most tire shops have a guide to let you know if they will fit. As far as brand depends if your on road. Off road or both. You will want a rim with the correct load rating. That is stamped into the backside of the rim.
Old Feb 17, 2017 | 09:12 PM
Bigdtaylor88
Ok, thank you for the info.
Old Feb 17, 2017 | 09:47 PM
p38251's Avatar
p38251
NP. FYI you can find nice rims for under $200.00 each.
