J1850
Old 02-16-2017, 09:44 PM
5.7 35's's Avatar
5.7 35's
5.7 35's is offline
New Member
Default J1850
Wondering if anyone can point me in the right direction. Check engine light is on what comes up is j1850 no transmission, also no cluster messages, wrong VIN/ mismatch. Any help would be appreciated. Thanks
Old 02-16-2017, 11:19 PM
p38251's Avatar
p38251
p38251 is offline
Did you change the PCM?
Old 02-16-2017, 11:35 PM
5.7 35's's Avatar
5.7 35's
5.7 35's is offline
New Member
No I didn't change pcm. Should I? Bad ground? Short somewhere?
Old 02-17-2017, 09:40 AM
jkeaton is offline
Dodge Forum Administrator
What year? What engine?
Old 02-17-2017, 03:41 PM
5.7 35's's Avatar
5.7 35's
5.7 35's is offline
New Member
2004 5.7 automatic 4x4
Old 02-17-2017, 07:26 PM
p38251's Avatar
p38251
p38251 is offline
Usually the mismatch shows up after a pcm change, because the pcm was flashed incorrectly.
Battery good? All fuses and relays good?
Old 02-17-2017, 08:20 PM
5.7 35's's Avatar
5.7 35's
5.7 35's is offline
New Member
Yes battery is good and I switched relays around, I didn't test them. The only thing I have done was try to download a supercharger tuner a couple weeks ago...It said it already had a tune of some sort...360$ gone
Old 02-17-2017, 09:01 PM
p38251's Avatar
p38251
p38251 is offline
Try to use the tuner to return to stock. You can't load multiple tunes. This maybe the cause of the mismatch code, and the others.
Old 02-17-2017, 09:31 PM
5.7 35's's Avatar
5.7 35's
5.7 35's is offline
New Member
Super chips
Old 02-17-2017, 09:41 PM
5.7 35's's Avatar
5.7 35's
5.7 35's is offline
New Member
Truck came with a tune idk what one...My tuner won't let me download cuz it says not stock file. Reset PCM?
