Out of ideas..What can i check next?
Old Mar 2, 2017 | 05:43 PM
p38251's Avatar
p38251
Have an injector leak down test done.
Old Mar 2, 2017 | 05:47 PM
mandob73's Avatar
mandob73
Injectors are new..but at this point, guess it wouldnt hurt to try that too
Old Mar 2, 2017 | 05:52 PM
mandob73's Avatar
mandob73
Just took truck into another shop...bank 1 rich..bank 2 lean.. WTH
Old Mar 4, 2017 | 12:52 AM
AIR_RAM's Avatar
AIR_RAM
Originally Posted by mandob73
ive been told that before, but ive already gone thru about 3 tank fulls of fuel, with so many differrent types of injector and fuel system cleaners.....new oil..nothing works....gonna do a compression test next
Fuel injection cleaner does not treat bad gas...
Water remover does...
If you have not done this yet, I would give it a shot.
Put a bottle of HEET into the tank. Drive it till its empty and refill with quality fuel. It will still run like crap until the HEET mixes with the water and the water is completely burned out... It does not "fix" the issue immediately... It typically takes 2-3 tanks after the heet for it to be completely out.
SPEED SAFE, AIR RAM
Old Mar 4, 2017 | 01:58 AM
AIR_RAM's Avatar
AIR_RAM
I think a clogged or failing CAT could also cause these issues...
SPEED SAFE, NICK
Old Mar 4, 2017 | 09:24 AM
mandob73's Avatar
mandob73
I have already changed out driver side CAT, working to have passnger side CAT changed out, i've gone this far, also, i'll give the HEET a try, thanx guys
Old Mar 4, 2017 | 10:30 AM
TrueDogman's Avatar
TrueDogman
Think about valve springs
Old Mar 4, 2017 | 10:43 AM
mandob73's Avatar
mandob73
If the new CAT or the HEET dont work, that would be my next step i think...
