money pitt
Old Apr 2, 2017 | 12:43 PM
rbrunswi's Avatar
rbrunswi
Default money pitt
i have a 2005 ram 1500 4.7 with 220000 miles. problem started with week power shutting off at idle and bad valve rattle .so i replaced the timing chains oil pump and water pump.i start it up and it runs great and quiet just wont idle .i flash the pcm now wont start cleaned battery and replaced starter ignition switch . no codes when turning over it tries to start and some black smoke from tail pipe.
Old Apr 2, 2017 | 07:48 PM
p38251's Avatar
p38251
Codes?
Old Apr 2, 2017 | 09:18 PM
rbrunswi's Avatar
rbrunswi
still no codes
Old Apr 3, 2017 | 10:55 AM
superdak05's Avatar
superdak05
2 things, replace throttle positioning sensor, and crank shaft sensor, if truck is cranking but wont fire, something electrical is not sending a signal, these are the 2 most common issues with the 4.7
Old Apr 3, 2017 | 10:57 AM
superdak05's Avatar
superdak05
don't forget cam sensor too, buy oem, these 4.7 don't like aftermarket
Old Apr 4, 2017 | 04:30 PM
rbrunswi's Avatar
rbrunswi
thanks will try it
Old Apr 7, 2017 | 10:22 PM
mrfblack08laramie's Avatar
mrfblack08laramie
Plugged cat?
