Loud whine coming from accessories. Which one?
Old Oct 10, 2017 | 09:44 PM
  #21
bdhuntr's Avatar
bdhuntr
If your A/C works, it's easy to test.... Start the engine, let it idle, turn on the a/c. If the noise doesn't change when the compressor cycles, it ain't the compressor.
I can tell you it doesn't change. But the noise is not at idle. The RPM's have to get to at least 1500-1800 before the noise starts.
I'll have a stethoscope tomorrow.
Old Oct 11, 2017 | 12:43 PM
  #22
big guy's Avatar
big guy
my 03 had very similar characteristics..... turned out to be a/c clutch bearing
Old Oct 11, 2017 | 06:10 PM
  #23
bdhuntr's Avatar
bdhuntr
I think it is likely that, but I just used a mechanic’s stethoscope and listened to the compressor clutch, water pump, power steering pump and even the new alternator and can’t pin it on any single component.
I took a video of it but for some reason I can’t seem to embed it from youtube. Here’s a link if you can listen to it and give me your opinion.
https://m.youtube.com/watch?v=IfnvMQ...ature=youtu.be
Old Oct 13, 2017 | 09:01 AM
  #24
bdhuntr's Avatar
bdhuntr
Default AC clutch change/repair
I think it's likely the AC clutch pulley. It's a discontinued part and the ones I've found are $$. You can buy a compressor complete with the clutch pulley for less. But probably not compatible if I just wanted to install the clutch pulley.
You can get rebuild kits. Anyone ever rebuild their clutch pulley with new bearings, etc?
