05 1500 5.7 helppppp
Old Jun 20, 2017 | 05:55 PM
Flowerskevin99's Avatar
Flowerskevin99
Default 05 1500 5.7 helppppp
Ok so at red lights my truck likes to shut off then starts right back then while I'm driving from time to time around 30 to 50 mph at a steady foot throttle the rpms go up and down really fast no check light and I have no idea where to start any suggestions would be helpful
Old Jun 20, 2017 | 07:47 PM
Throttle position sensor?
Moving this to third gen ram for ya. Welcome to DF!
Old Jun 20, 2017 | 08:10 PM
Flowerskevin99
Thank you my mistake lol and that's located right on the throttle body or next to the throttle body I should say correct ? I cleaned out the throttle body it wasn't that bad as I cleaned it about a year ago when I installed my cold air kit.
Old Jun 24, 2017 | 09:10 AM
Luke M's Avatar
Luke M
Yes, that is correct. A quick google search can show toy the exact location. Its easy to replace. I had the same problems with my 04, however I found the problem to be in the manifold gaskets, it would suck in too much air but not enough to throw a code. I would start with the TPS as its easy to replace, the manifold gaskets are cheap but a real PITA to replace LOL
