2002 Ram 1500 A/C condenser fan not working
Old Jul 24, 2017 | 02:31 PM
DrewMirq's Avatar
DrewMirq
Default 2002 Ram 1500 A/C condenser fan not working
Hi everyone, this is my first post here. A few months back, the AC in my 02 Ram 1500 stopped working but would work when the truck was driving over 30 mph or so. I checked the fuses to discover the condenser fan fuse was blown. I replaced it and the AC worked for about another 2-3 months and then stopped working again (still worked while going 30 mph or more). I checked the fuse again and the fuse was good now but the condenser fan was not running while the truck was running with the AC on. I tapped the fan and tried to spin it manually with no success. Any suggestions on where I should go from here?
Old Jul 24, 2017 | 04:50 PM
Are you getting power to the fan? Does it have a good ground?
Old Jul 24, 2017 | 06:05 PM
bdhuntr's Avatar
bdhuntr
If you can't spin it manually, it sounds like it locked up, which will definitely blow a fuse.
Old Jul 25, 2017 | 04:42 PM
DrewMirq's Avatar
DrewMirq
I meant to say when I spin it by hand, it doesn't start spinning on it's own...it's not locked up. Also, the fuse blew previously but is good right now
Old Jul 25, 2017 | 04:45 PM
DrewMirq's Avatar
DrewMirq
relay and fuse are both good. I'm gonna have to locate my voltmeter or buy a new one before I can test power
Old Jul 25, 2017 | 05:04 PM
DrewMirq's Avatar
DrewMirq
I actually made a test light with a tail light bulb and the fan is not getting power with air conditioning on.
Old Jul 25, 2017 | 05:57 PM
Need to find out where the power is lost. Start backtracing the circuit, and see what you find.
