brakes wont build up
Old Oct 1, 2017 | 06:08 PM
dodgetrkman's Avatar
dodgetrkman
Default brakes wont build up
so i replaced all 4 of my rotors, calibers, and pads got late so had to finsh next day but now bleed brake got all clear but brakes still will not build up it is a 2005 ram 1500 4x4 quad-cab with 20 inch wheels and yes i bleed the master to and when my son pumps the brakes it sounds like i can hear fuild and air being sucked id but no leaks any where and now after the 15th time bleeding abs and brake lights are on any help
Old Oct 1, 2017 | 08:51 PM
Still air in the system. Recheck for leaks. Inspect anything you touched CAREFULLY.
Old Oct 2, 2017 | 06:21 PM
bdhuntr's Avatar
bdhuntr
Bleed again. Make sure you start at right rear, then left rear, right front and end at left front.
