2006 Ram 1500 5.7 Electrical Issue
Old Oct 4, 2017 | 09:02 AM
jhataway's Avatar
jhataway
Default 2006 Ram 1500 5.7 Electrical Issue
I have a 2006 Dodge Ram 1500 Mega Cab with a 5.7 Hemi. The truck starts fine and will shift into reverse with no issue but when i shift into drive the engine shuts off. If i unplug the alernator wires then the truck will shift into drive and all is good. I replaced the alternator and battery but this has not fixed the problem. Any help is appreciated.
Old Oct 4, 2017 | 11:40 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
When you say WIRES, you mean the 2 pin connector, correct ?
Old Oct 4, 2017 | 02:00 PM
jhataway's Avatar
jhataway
Yes the 2 pin connector.
Old Oct 5, 2017 | 01:51 PM
TNtech's Avatar
TNtech
The best I can figure is you have a wiring problem in the harness. Need to see if any DTCs are setting and try to find commonality with the field coil circuit.
Old Oct 5, 2017 | 02:02 PM
jhataway's Avatar
jhataway
Thank you. DTCs? can you give me more direction on this?
Old Oct 6, 2017 | 12:29 PM
TNtech's Avatar
TNtech
Sorry, (Diagnostic Trouble) Codes in the PCM or TCM. SO we can look for related issues and try to track it down.
Old Oct 6, 2017 | 02:16 PM
jhataway's Avatar
jhataway
The check engine ligth is not on. I have checked for any codes problems but everything checks out good. I am looking for a bad wire or something like that now.
