2007 Hemi taking tons of trans fluid? (9+ quarts)
Old Oct 31, 2017 | 12:14 AM
pryvisee's Avatar
pryvisee
Default 2007 Hemi taking tons of trans fluid? (9+ quarts)
I dropped the trans pan (as well as replaced both filters) and let it drain for around 1.5 days because I was waiting for O'Reilly to get a new pan shipped as it was dented and gasket was leaking. I don't know how much fluid I drained but I'm already up to 9 quarts of trans fluid that I've put in.
Procedure I do when checking. Drive it around for around 10 minutes, cycle through park neutral and drive then put it in park and check.
I've added 9 quarts and still on the half way mark between cold and hot.. Should I keep adding?
Old Oct 31, 2017 | 12:40 AM
44dakota's Avatar
44dakota
not sure what tranny you have ,but, i put 12 quarts in my 46re after dropping the valve body..
Old Oct 31, 2017 | 09:04 AM
big guy's Avatar
big guy
Drive for an hour or so to get trans up to temp... suppose to be at 180 degrees when checking fluid level. Cold tranny will show a lower level..... as trans warms the level on stick will rise accordingly.
Going on memory pretty sure I put 9 1/4 into my 4X4..... 2 wheel drive has smaller pan so less fluid is needed. ALWAYS never over fill...... slightly under filled is better than overfill.
Old Oct 31, 2017 | 09:26 AM
primem's Avatar
primem
no idea which trans you got...shouldn't you be checking the fluid level in neutral?
Old Oct 31, 2017 | 04:57 PM
big guy's Avatar
big guy
545RFE... Check in Park
Old Nov 1, 2017 | 02:27 PM
primem's Avatar
primem
says check in park in the service manual but the dipstick says idle in neutral...unless someone changed out the dipstick on my 2007 dh 2500 with 545rfe
