Transmission No Gears??
Old Nov 1, 2017 | 09:27 PM
CharlesC's Avatar
CharlesC
Exclamation Transmission No Gears??
2005 Dodge Ram 2500 4x4 Laramie
Hello, I am new to this forum.
I was driving my truck the other night and the truck was driving just like any other normal day.
​​Suddenly my truck just reved up which was rather odd as I did not hear any sounds or indicators from my transmission which led me to think it can't be my transmission blew, I took my foot off the gas for a moment and when I tried to push the gas again the truck just reved up rpm but wouldn't go accelerate.
At a complete stop I put the truck into any gear from P R N D 2 1 I hear a click from the shifter arm connected on side of transmission although the truck will not move forward or reverse even if I turn on my 4x4.
I checked the fuse box under the hood and replaced the ""Transmission Relay #59"" and ""Transmission Module Fuse #5"" in the fuse box and still the truck doesn't move.
If someone could possibly give me any insight and helpid be very greatful.
Old Nov 2, 2017 | 04:09 PM
cruzer55's Avatar
cruzer55
Did you check U-joints ?Just a thought...........................
Old Nov 3, 2017 | 10:18 AM
66three83's Avatar
66three83
I’m sure a joint failure like that would be self evident. Especially since it doesn’t move in 4WD as well. It’s either something simple or something catastrophic. A trans shop is the only way to find out, unless you know your way around a very complex piece of engineering.
Old Nov 3, 2017 | 10:19 AM
66three83's Avatar
66three83
Whatever it is, I’d be grateful to know. Keep us informed!
Old Nov 3, 2017 | 11:02 AM
HemiLonestar's Avatar
HemiLonestar
Any codes?
Old Nov 30, 2017 | 03:56 PM
Cody Norris's Avatar
Cody Norris
Having the exact same issue with an 07 1500 right now. Did you happen to figure out what your issue was?
Old Nov 30, 2017 | 09:35 PM
66three83's Avatar
66three83
Another one of those one time posters who want all the answers, but then doesn’t share the solution when they find it!!
