5.7 hemi flexplate problem
hello everyone i need help i have figured the noise coming from my engine is coming from my flex plate it makes a clunking noise i seen a few videos saying it was there flex plate so i was just wondering is there a inspection window ? so i could just look and see?
secondly if i have to replace flex plate can i do it with the transmission in or do i have to take the tranny out?
help is greatly appreciated thank you in advance
Should be an inspection plate between engine and trans. Likely have to pull the starter as well, to get it off.
If the flexplate needs changed, either the trans, or the engine, will need to come out.
