2008 dodge ram no reverse lights?? HELP!
Old Nov 9, 2017 | 09:43 PM
RamedHemi's Avatar
RamedHemi
Exclamation 2008 dodge ram no reverse lights?? HELP!
Need some help here. From reading some things online seems these trucks have no reverse light fuse?? checked manual and box under hood and cannot locate one. I don't believe these have any fuse panels inside the truck. Any help here. Lights where on and they just went out. Could I have a bad ground? I hope this will be an easy fix or at least not too hard to figure out. I need to get these working as I use the truck for plowing and cannot function without them.
Old Nov 9, 2017 | 10:45 PM
RamedHemi's Avatar
RamedHemi
Do we know where this located? This all happened tonight. Lights where on, flickered a lil then went out. I have auto trans.
Old Nov 9, 2017 | 10:59 PM
RamedHemi's Avatar
RamedHemi
what does this do? You had same issue with lights? I read that if this was bad truck wouldn't start or shift from park? I don't have those issues.
Old Nov 11, 2017 | 07:36 PM
RamedHemi's Avatar
RamedHemi
problem was my aux lights i have under my bumper. One light is rusted and out and the ground was corroded too. I have them taped into truck reverse lights. problem fixed.
