grinding sound while turning what is it?????
Old Nov 17, 2017 | 08:56 PM
swamper's Avatar
swamper
Question grinding sound while turning what is it?????
Tonight as I left the store my truck made a loud grinding sound like metal on metal while I turned right also it did it as I drove forward then after a few minutes of driving it wasnt as loud and could barley hear it.It was so loud i was going to call the tow truck but I made it home.Does anyone have a clue as to what this could be??thanks
03 ram 1500 4x4 hemi.
Old Nov 17, 2017 | 08:58 PM
Could be anything. Pull a wheel off and inspect.
Old Nov 19, 2017 | 10:44 PM
lxman1's Avatar
lxman1
Site Moderator
Sounds like possibly the ball joints, control arm bushings or a hub bearing.
Old Nov 20, 2017 | 04:52 PM
66three83's Avatar
66three83
I’ve never heard ball joints or control arm bushings grind. Squeak, yes, but not grind. He is describing a sound like worn pads on a disk. Bearings or cv joint. Or possibly brakes.
Old Nov 20, 2017 | 04:58 PM
66three83's Avatar
66three83
And, yes, of course, lift it and inspect. Spin the wheels, shake them side to side and up and down. Look for a split boot. All the things you would do to pinpoint where the noise is coming from.Then report back with us.
Old Nov 23, 2017 | 07:42 PM
swamper's Avatar
swamper
it ended up being the wheel hub.
Old Nov 23, 2017 | 08:00 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
I had something similar to this that I just diagnosed today. The symptoms were a groaning sound that was audible below 30mph when slowing to a stop; a wiggle in steering play; and, a grinding/clanging noise at times when backing.
This video does a great job for diagnosing bad bearing.
