Quick exhaust idea
Old Nov 27, 2005 | 02:24 PM
IshouldaGOTtheHEMI's Avatar
IshouldaGOTtheHEMI
Default Quick exhaust idea
Ok so i got this idea. what if i bring a dual exhaust system out each side of my truck, right behind my running boards, with a rectangular tip. kinda like the gibson super truck exhaust but out each side. is that possible and is there a system already like that? i tried searching and came up with nothing.
also if this is a stupid question.....sorry! kinda new
Old Nov 27, 2005 | 02:40 PM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: Quick exhaust idea
ORIGINAL: IshouldaGOTtheHEMI
Watch how close you run the pipes in relation to the gas tank. Also, if you exit the exhaust behind the running boards, but in front of the rear tires expect damage over time to your rear wheels if you drive your truck on a regular basis.
Old Nov 27, 2005 | 04:14 PM
HemiBuell's Avatar
HemiBuell
That is very possible. You should do it, I'll help you make up some drawings and find a shop to bend the pipe, and we can go into business.
Old Nov 27, 2005 | 05:22 PM
IshouldaGOTtheHEMI
awsome! thanx so much! i have a few drawings already! i better start savin up..kinda tite on money right now so.....itll happen within the next few months.
u guys think i should do a single rectangular tip on each side or dual rectangular on each side?
Old Nov 27, 2005 | 11:13 PM
GotHemi?'s Avatar
GotHemi?
Don't worry about hurting your tire or rim with the heat. I have run over 30,000 miles through my sure truck exhaust from Gibson without a single blemish or trace.
Old Nov 27, 2005 | 11:21 PM
CarGuyOhio's Avatar
CarGuyOhio
ORIGINAL: GotHemi?
Heat is not the issue. It is the other crap what will oxidized and, if you have steel rims, accellerate corrosion. If you live in a snow free, salt free climate it will help. Also cleaning and polishing your rear rims will help to prevent the issue.
Old Nov 27, 2005 | 11:25 PM
IshouldaGOTtheHEMI
well, i got alumium rims so i think im good. plus dont alot of cars run side exhaust in front of the rear tire? like say the rt/10?
Old Nov 27, 2005 | 11:28 PM
CarGuyOhio's Avatar
CarGuyOhio
Yes my RT10 does. I do not drive it on a regular basis (19K miles) and the wheels get polished several times a year. Talk to some Ford owners about side exhaust and rear wheel damage, many have experienced it.
With your aluminum rims just polish them occasionally to keep the oxidation from setting in.
Old Nov 27, 2005 | 11:48 PM
IshouldaGOTtheHEMI
awsome thanks!
and that ford thing....thats why we go with dodge now isnt it?!?
my dad had a '97 ford taurus once. engine fell out of it on our way home.
