Dtc P1391. 2002 ram 1500
Old Jan 18, 2018 | 08:24 AM
Are they both mopar sensors now?
Old Jan 18, 2018 | 10:40 PM
shanes76's Avatar
shanes76
Neither are, it’s developed a miss when it’s cold now, and hesitates
Old Jan 19, 2018 | 08:24 PM
You really want mopar sensors in there....... the aftermarket fellers just don't work as good.
Old Jan 22, 2018 | 06:21 AM
shanes76's Avatar
shanes76
After it runs about 6 or 7 minutes the miss disappears and runs great, so I don’t think it’s related to the sensors to be honest
Old Jan 22, 2018 | 08:28 AM
Have you checked fuel pressure? Wonder if it is a bit low, and when the truck goes into closed loop, the O2 sensors compensate?
Old Jan 22, 2018 | 03:23 PM
shanes76's Avatar
shanes76
Well it started messing up real bad today after sitting for a few hours, I didn’t let it warm up just jumped in and went and it was terrible, so I pulled over, used a code reader(p1391) same as before, cleared the codes and it ran fine so I would rule out fuel pressure
Old Jan 23, 2018 | 07:31 PM
shanes76's Avatar
shanes76
I got some freeze frame data, the short term fuel was at 0 and long term fuel was at -3.1 when I get code, I accidentally erased the reader so now I have wait till it happens again
From what I’ve read, total of both should be around 10% Engine load was 0 and rpm around 796 speed was 0 My scanner only does freeze frame at time of the cel
Old Jan 23, 2018 | 09:31 PM
Hhhmmmm...... Are you still getting the 1391 code?
Old Jan 24, 2018 | 10:50 PM
shanes76's Avatar
shanes76
Yes still getting same code
Old Jan 25, 2018 | 09:27 PM
shanes76's Avatar
shanes76
Passenger side timing chain is loose, can almost take off with fingers,
