Hvac not working
Old Jan 13, 2018 | 01:48 PM
mikea1975's Avatar
mikea1975
Default Hvac not working
I checked blower, it works. Installed new regulater. Checked fuses. Checked wiring. Don't know why heater is not working. Any suggestions?
Old Jan 13, 2018 | 03:45 PM
What is it not doing? Not blowing? Not blowing warm?
Old Jan 13, 2018 | 03:50 PM
mikea1975's Avatar
mikea1975
not doing anything. I believe the directional swith is working, cause I can hear it switching , but no air flow at any setting
Old Jan 13, 2018 | 05:01 PM
Gone Fishin's Avatar
Gone Fishin
Check to make sure the recirc air door hasn't broken off and is blocking the air flow
Old Jan 14, 2018 | 04:36 PM
FaceDeAce's Avatar
FaceDeAce
Hi Mike, it is still not clear what your problem is. Please describe better.
Is this a fan problem, or a temperature control problem, or a mode problem
- Is the problem that the fan blower not working? Is it turning on, speeding up, slowing down as you adjust the fan ****.
- Is the problem that there is no temperature control? Does the temperature increase/decrease as you adjust the temperature ****
- Is the problem that there is no mode control? Does it change from floor to dash to windshield as you adjust the mode ****.
If you want some help. Which is it, and be absolutely specific. They are not the same and are mutually exclusive.
