2007 1500 2in lift installed
Old Jan 21, 2018 | 09:33 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Default 2007 1500 2in lift installed
I wanted to gain little more clearance off-road.
Here is before the install.
Here is after the install
I ordered some coil spring spacers from Ebay.
https://www.ebay.com/itm/FOR-DODGE-R...72.m2749.l2649
As I was working on the front suspension, I noticed I needed upper and lower ball joints, I ordered new Moog upper and lower control arms from Rockauto.com. Of coarse I got an alignment after all was installed.
Out back I ordered Superlift add a leaf kit
https://www.summitracing.com/parts/slf-2517
Once installed I noticed the rear shocks were not fully extending as much as when the suspension is fully extended, so I ordered these Ram 2500 shock extensions, they only needed the factory shock hole drilled in a lower position than the provided hole.
https://www.ebay.com/itm/Rear-Shock-...NaU~8C&vxp=mtr
For shocks, I went with Gabrel MaxControl Shocks.
Just for fun, I got some simple fender flairs, Super easy to install.
https://www.ebay.com/itm/For-02-08-R...72.m2749.l2649
I'm not sure if I posted this but I also bought this bull bar from Ebay. This will do untill I want to spend some $$$ for a winch bumber.
https://www.ebay.com/itm/06-08-Dodge...item1c9e47da54
For camping, I found a soft top camper shell from Bestop. I love the easy setup and disassibablity. Aluminum and fiberglass shells are heavy and you have to have somewhere to store them when not in use.
