06 ram lighting
https://lightbarsupply.com/products/mega-bundle
This is the link to the set that i got. im not sure what the draw is but this page has all the info about them that i do. im new to this kind of stuff but a shop i took it to wanted to charge me 1k to put them all on so i just want to try and learn to do it myself . any help is appreciated
462 watts at 12 VDC is 38.5 amps.....Yes, you will need to run separate wires, relays and switch. Hefty wire, hefty relay, hefty switch....if you plan on turning them all on at the same time. Thats a crap ton of light.....probably going to need to beef up your alternator as well, if there is one capable of handling that much.
Edit, I see it comes with a harness. Yes, use that. Stock wiring wont handle it.
I assume because the supplier does not expect all to be on at the same time? OP does not mention if he would do that, so the 38.5 amps would be worst case scenario.
