2005 Dodge Ram 1500 Lamp Out Light
Old Jan 30, 2018 | 07:20 AM
darmstrong@briggsbeams.com's Avatar
Default 2005 Dodge Ram 1500 Lamp Out Light
Lamp Out light came on. I found a back up light and a license plate light out. Replaced both. Lamp Out light still on. Is there a reset?
Old Jan 30, 2018 | 07:28 AM
Is there another bulb out?
Old Jan 30, 2018 | 07:35 AM
Default 2005 Dodge ram lamp out light
no other lights out
Old Jan 30, 2018 | 08:50 AM
bdhuntr's Avatar
bdhuntr
Check the wires and look for chafing causing it to ground out. That happened to my right tail lights.
Old Jan 30, 2018 | 02:22 PM
HemiLonestar's Avatar
HemiLonestar
Check the bulbs in your taillight circuit boards. Those things are a known problem, your bulb may be good but any kind of intermittent contact will cause the light and the annoying *** ding. There's no reset other than when you figure out the problem.
Old Jan 31, 2018 | 01:00 PM
Went back and checked all lights again. One of the brake lights was dimmer than the other ones. Replaced it and the Lamp Out light finally went out.
Thanks for all of your help.
