2006 dodge ram with hemi
Old Feb 7, 2018 | 11:11 AM
mors25's Avatar
mors25
Default 2006 dodge ram with hemi
truck starts but will not idle i have changed egr valve but that didn't work. any suggestions or anyone had this problem before?
Old Feb 7, 2018 | 11:37 AM
Any codes? Last tune up? Mileage? Need more information.
Old Feb 7, 2018 | 12:33 PM
mors25's Avatar
mors25
no codes. just did tune up, 203000, it will start but dies right after start up i have changed egr valve. it ran fine until one day it started doing what its doing.
Old Feb 7, 2018 | 12:34 PM
mors25's Avatar
mors25
its a 2006 dodge 1500 with 5.7 hemi
Old Feb 8, 2018 | 12:05 AM
66three83's Avatar
66three83
Disconnect negative battery lead for a couple minutes, then try starting. Your transponder in the column may not be communicating with your key.
Old Feb 12, 2018 | 12:00 PM
HemiLonestar's Avatar
HemiLonestar
Most likely not that, he's probably tried this a few times. If SKIM doesn't get a good signal and shuts off the engine, after a few tries it would lock the PCM and then it wouldn't start. I'm assuming you did plugs as well, were all the coils seated properly? Also lack of idle sounds like you might have knocked a hose loose doing the plugs, check the hose going from the intake manifold to the power brake booster.
