PLEASE HELP!! 48re transmission problems
Old Feb 15, 2018 | 10:31 PM
Newlaree99's Avatar
Newlaree99
Default PLEASE HELP!! 48re transmission problems
Hey guys I have a 2006 ram 2500 5.9 cummins, 4x4, automatic, 188,000. Has 35's small lift and a bully dog tuner. Earlier today I was driving and got on the throttle a little heavy (probably 3/4 or so) from about 30 mph and it took off fine and then the RPM's shot up and the truck did not pull. Tires were definitely not spinning btw. It now shifts perfectly fine under normal throttle but every time I get into it it does the same thing. Revs and does not take off! Any advice will. E greatly appreciated!
Old Feb 16, 2018 | 08:53 AM
Is the trans slipping? Or just not engaging at all? If you start out easy on the pedal, and then press it down harder, does it do the same thing?
Old Feb 16, 2018 | 08:06 PM
Newlaree99's Avatar
Newlaree99
If you start from a stop and go easy, then get on it it does the same thing. I think it is slipping but I really don't know? When it does it, it doesn't pull at all. But like I said if you drive it easy it never does it. Just when you get in the throttle
Old Feb 17, 2018 | 08:57 AM
They still used the 48RE in the 06 trucks? Wow......
Anyway, crawl under the truck. On the drivers side of the trans, about halfway back, there is an 8 pin connector that plugs straight down into the top of the valve body. (on the outside of the trans) Unplug it. Go for a drive. Your trans will have ZERO automatic function, you will have to start out in first, and shift as appropriate. You also will not have TCC, or O/D, so, keep it slow and easy. If the trans goes into the gear you tell it to, when you tell it to, and doesn't exhibit undesired behavior, (like slipping when you get into it....) you just have an electronics problem, and it'll be an easy fix. If it still slips, time for a rebuild.
Old Feb 20, 2018 | 09:09 PM
Newlaree99's Avatar
Newlaree99
Okay I'll give it a try tomorrow and see what happens. Thank you!
Old Jan 13, 2022 | 08:35 AM
Guswolf60's Avatar
Guswolf60
Default I'm having an intermittent problem with my Trans. The 8pin connector you speak of.
Whats the easy fix for the electronic problem? That 8 pin connector seems to be the central point of my problem. The Trans will seem to drop out of gear and I get a dead throttle pedal. It may do that several times in a row then take off and drive normal.
Old Jan 13, 2022 | 05:49 PM
Replace the electronics. Governor pressure sensor, and solenoid. You can get 'em as a set, for less than a 100 bucks. I replaced the output speed sensor as well, just for grins. Fixed my problems.
