4wd problems
Old Mar 8, 2018 | 11:51 PM
Dodgealltheway's Avatar
Dodgealltheway
Default 4wd problems
i have a 2007 Dodge Ram 1500. It has the electronic 4wd ****. Every time I put it in 4 wheel high, the light comes on saying it’s locked in but the front wheels don’t spin. It just makes a bad clicking sounds like gears are slipping. Any ideas on what the problem is or how to fix it? Thanks
Old Mar 9, 2018 | 11:05 AM
FaceDeAce's Avatar
FaceDeAce
Does the front engage when you goto 4 lo ? Do the front wheels spin in 4 lo ?
Old Mar 10, 2018 | 08:43 AM
Dodgealltheway
No. The wheels don’t spin at all. Almost feels like gears are stripped somewhere.
Old Mar 10, 2018 | 09:40 PM
FaceDeAce's Avatar
FaceDeAce
Well then ... unfortunately there is a problem
There are three places the problem could be:
- the front differential pinion and ring gear (very unlikely)
- the front drive shaft from the transfer case to the front differential. Blown CV joint (possible)
- shift fork or pads out of place inside the transfer case. (likely). The fix is to remove the transfer case from the truck and disassemble, replace/repair what is found
- shift motor encoder faulting (likely). Remove the encoder motor and test.
Are there any grinding or gear crunching type sounds in normal driving (2wd?).
Old Mar 11, 2018 | 09:12 AM
Dodgealltheway
During driving in 2wd there are no grinding nosies. It’s jusr werid because the trucks 4wd worked great until a week ago. Just instantly stopped working, no lead up to it or me being rough on it.
Old Mar 11, 2018 | 12:23 PM
66three83's Avatar
66three83
I would bet on the actuator.
