Transmission "buzzes" when putting it into drive
Old Dec 1, 2005 | 02:13 AM
glock45's Avatar
glock45
Default Transmission "buzzes" when putting it into drive
I have a 02 1500 QC and have no problems with anything except an annoying sound from the tranny when I am putting it into gear.
It is a buzzing sound that lasts for about 3 seconds after it is put into gear.
When looking this up in the service manual I saw the following causes:
BUZZING NOISE
CAUSES CORRECTION
1. Fluid Level Low 1. Add fluid and check for leaks.
2. Shift Cable Mis-assembled. 2. Route cable away from engine and bell housing.
3. Valve Body Mis-assembled. 3. Remove, disassemble, inspect valve body. Reassemble correctly if necessary. Replace
assembly if valves or springs are damaged.Check for loose bolts or screws.
4. Pump Passages Leaking. 4. Check pump for porous casting, scores onmating surfaces and excess rotor clearance.
Repair as required. Loose pump bolts.
5. Cooling System Cooler Plugged. 5. Flow check cooler circuit. Repair as needed.
6. Overrunning Clutch Damaged. 6. Replace clutch.
I have checked the fluid and it is at the proper level and color and the tranmission is not exibiting any other problems - just the buzzing noise for about 3 seconds after it is put in gear.
Is this something I should worry about or is this a normal thing?
Old Dec 1, 2005 | 05:03 AM
muddauber5.7's Avatar
muddauber5.7
Default RE: Transmission "buzzes" when putting it into drive
If it's the buzzing while your putting it in gear, forward or reverse. Then every dodge ram from 2002 on does it. It's the electronic trans. shifting and I've been told it's completely normal.
Old Dec 1, 2005 | 05:54 AM
abarmby's Avatar
abarmby
Yup.mine does it for just over 1 sec.
If you notice, when you change from drive to reverse it will also make that sound.
2003 Quad cab hemi.
Old Dec 2, 2005 | 01:54 AM
Hemi_Dub's Avatar
Hemi_Dub
i have an 04 HEMI Sport and it does it as well when shifting to reverse. i went to the dealer and they told me just to run it like that until if or when it brakes or what ever, thats what the warrenty is for. what a b*tch
Old Dec 2, 2005 | 02:06 AM
05_black_beast's Avatar
05_black_beast
It sounds like the solenoids are buzzing...Assuming that truck has the 5-speed trans?
The FWD overdrives in Chrysler minivans are notorious for it too.
