Crankshaft Position Sensor/Misfire Codes
Old Mar 19, 2018 | 01:40 AM
Bparker86's Avatar
Bparker86
Default Crankshaft Position Sensor/Misfire Codes
I have a 2003 Dodge Ram 1500 SLT 4X4 4.7
Had a brand new motor put in 2 years ago. It has been running great up until 3 weeks ago it threw a Crankshaft position sensor code. So I went to AutoZone and bought the DURALAST SU3181. That didn't work. Then replaced Camshaft Sensor, still no luck. Now I realize I'm in limp mode because it won't exceed 3,500 RPMs. Now getting these codes:
P0315: Unknown code
P0300: Random/Multiple Cylinder Misfire Detected
P0339: Crankshaft Position Sensor A Circuit Intermittent
P0335: Crankshaft Position Sensor A
Any ideas on what could possibly be wrong? Could a clogged catalytic converter make these codes? Any help would be greatly appreciated.
Old Mar 19, 2018 | 02:06 AM
Bparker86's Avatar
Bparker86
Or could it be the aftermarket sensors from DURA(never)LAST?
Old Mar 19, 2018 | 05:14 PM
Ramchu's Avatar
Ramchu
That P0315 code : Crankshaft Position System Variant Not Learned
More info on that HERE
Old Mar 19, 2018 | 05:30 PM
Bparker86's Avatar
Bparker86
Okay, so I decided to clean the crankshaft position sensor from the factory and put it back in, now it runs great and throws no codes. We will see how long that lasts.
Old Dec 14, 2021 | 05:54 PM
dannysports23's Avatar
dannysports23
I am having the same issue. After replacing the sensor with another stock sensor im getting the same codes
