Question about how to tell if my timing chain needs to be replaced?
3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I have a 04 ram 1500 4x4 with a 4.7 that has 142,000 miles on it. I am noticing a ticking noise on start up that last about 3 or 4 mins then it goes away. I have read that it could be manifold bolts broke off that could be causing the noise. How can I tell if it is the timing chain with out taking it apart? Also, If it ends up being the timing chains do I have to pull the motor or is it something I can do with the motor left in the truck?
When I purchased the truck about 2 months ago the tick was not there. Then one cold morning I went to warm the truck up and thats when I noticed the noise. On cold mornings it sounds like a diesel truck is running.
I doubt that its a timing chain. They are more of a rattle sound. What you describe sound more like an exhaust manifold bolt being broken. Is it more noisy on one side of the engine?
