Rear axle bearing
Old Mar 31, 2018 | 11:40 PM
mike39648's Avatar
mike39648
Default Rear axle bearing
I just got a 2003 2500. The axle bearings are grinding a lot. Do I have to remove the tire to change out the rear axle bearing? Does it have a rear seal?
Old Apr 1, 2018 | 08:21 AM
Full floating rear axle?
You don't *have* to remove the tire, but, it sure makes it easier......
I suspect though, that if you have rear disc brakes, then yes, you need to remove the tire.
