Rear power door locks - both failed
Old Apr 15, 2018 | 01:43 PM
fostervs's Avatar
fostervs
Default Rear power door locks - both failed
2007 RAM 1500
First the rear passenger side, now the rear drivers side power door locks have failed.
I am assuming the power lock unit itself has failed. Is this a common problem?
Old Apr 15, 2018 | 05:53 PM
No. It’s not a common problem. Lol
Old Apr 15, 2018 | 06:13 PM
FaceDeAce's Avatar
FaceDeAce
Yes, can be a common problem if you have an active group and the rear doors are used alot. Check out a few of my notes here. Hopefully this is the find you need.
https://dodgeforum.com/forum/3rd-gen...r-windows.html
Old Apr 19, 2018 | 05:48 PM
karlmich's Avatar
karlmich
fix the broken wire in the Rubber sleave. know issue on drivers side rear especially. Re solder and shrink wrap the wires. you may find a few broken in there.
Old Apr 19, 2018 | 07:31 PM
66three83's Avatar
66three83
And they will break again, in a new spot. fixed mine a few times, I have given up at this point.
Old Apr 19, 2018 | 07:32 PM
66three83's Avatar
66three83
jkeaton, how can you say this is not a common problem??? You may have tons of posts, but since I joined this group 10 years ago, this has come up dozens of times!! That wire bundle is prone to failure, locks, window operation, lights, speakers, etc, all go through there. Please spare your non helpful comments if you don’t know what you’re talking about!!
