No power till key is on
Hey everyone.
So I have and 05 ram and none of my interior lights nor headlights work until key is in on position. I was told one thing could be iod fuse. I have checked every fuse and there is not one that says iod on it. I also texted every fuse and they are all good. Is there something else I may be missing? Thanks
Hey everyone.
I just fixed this same issue. it more than likely is a failing splice on the A114 circuit. I am an electrical Engineer and trouble shoot this very issue. at your ODB 2 port you are supposed to have 12 VDC all the time on pin 16 that is the lowest position on the right. you will probably find about 3-4.0 Vdc at the pin. I can tell you what i did but first are you "Electrically minded" ? because this will involve soldering and cutting the power wire behind the instrument clusterand running a parallel path back to battery (+) terminal and fuse it
for 7.5 amps. i supposed your key fob doesn't work or your radio when the car is on! also do you get a buzzing noice in the dash cluster with a faint red light ?
Hey everyone.
