Replacement Stock Headlights Causing Dashboard Codes to react
Old May 31, 2018 | 02:52 PM
KFlathers's Avatar
KFlathers
Default Replacement Stock Headlights Causing Dashboard Codes to react
So I recently replaced both headlight assemblies with new stock headlights. When the headlights are off everything works normal. But when the headlights are turned on and I go to use a blinker the lamp out code flashes and dings constantly. Not like the normal warning bell when a bulb is out. The third brake light also doesn't seem to work. I replaced all bulbs and checked fuses. I'm sure its something I am missing. Please, any ideas?!!
